I would like to understand why decrypting certain streams on VTM GO is not working.
This concerns, for example, the stream on https://www.vtmgo.be/vtmgo/escape-room~b7fc1de4-d993-4c1a-af61-0d2248ba2788.
Access to the site is free, but you need an account (login details attached) and probably also a VPN connection for Belgium.
I got the kid-key combinations via WidevineProxy2 and I use mp4decrypt because shaka-packager couldn't decrypt any resolution.
yt-dlp -F --allow-unplayable-formats <url.mpd> provides the following information:
Or with N_m3u8DL-RE:Code:ID EXT RESOLUTION │ TBR PROTO │ VCODEC VBR ACODEC ABR ASR MORE INFO ─────────────────────────────────────────────────────────────────────────────────────────────────────── 6 m4a audio only │ 192k dash │ audio only mp4a.40.2 192k 48k [nld] DRM, DASH audio, m4a_dash 5 mp4 412x232 │ 600k dash │ avc1.64000D 600k video only DRM, DASH video, mp4_dash 4 mp4 640x360 │ 1054k dash │ avc1.64001E 1054k video only DRM, DASH video, mp4_dash 3 mp4 960x540 │ 1871k dash │ avc1.64001F 1871k video only DRM, DASH video, mp4_dash 1 mp4 1280x720 │ 3506k dash │ avc1.64001F 3506k video only DRM, DASH video, mp4_dash 2 mp4 1920x1080 │ 5140k dash │ avc1.640028 5140k video only DRM, DASH video, mp4_dash
Decrypting the stream with mp4decrypt only works at a resolution of 960x540 or lower. Other programs (but not all) on the same streaming platform can be downloaded successfully at the highest resolution offered.Code:> [ ] Basic [X] Vid *CENC 1920x1080 | 5140 Kbps | 2 | 25 | avc1.640028 | 1274 Segments | ~01h24m46s [ ] Vid *CENC 1280x720 | 3506 Kbps | 1 | 25 | avc1.64001F | 1274 Segments | ~01h24m46s [ ] Vid *CENC 960x540 | 1871 Kbps | 3 | 25 | avc1.64001F | 1274 Segments | ~01h24m46s [ ] Vid *CENC 640x360 | 1053 Kbps | 4 | 25 | avc1.64001E | 1274 Segments | ~01h24m46s [ ] Vid *CENC 412x232 | 600 Kbps | 5 | 25 | avc1.64000D | 1274 Segments | ~01h24m46s [ ] Audio [X] Aud *CENC 6 | 192 Kbps | mp4a.40.2 | nld | 2CH | 1274 Segments | ~01h24m46s
How can I download and decrypt the highest resolution of the movie at the link provided above?
And what about subtitles? The film has subtitles that can be turned off in the player on the website, but they are not detected by the downloader (yt-dlp or N_m3u8DL-RE). Is there any way I can download them?
With OpenWV and Android CDMs at least, 540p is the maximum available resolution. For higher, maybe L1 is required. The website has some PlayReady-related code, but it seems it doesn't work correctly and requests to its endpoint with pyplayready-generated request return nothing.
International content on VTMGo is quite often L1. Check playback in the browser, if it limits you to 540p that usually indicates L1.
De MPD haal je zelf maar op, er zit nu een session aan vast, die deel ik liever niet.Code:{ "Filename": "Escape Room (2017)", "Keys": "5b8e8972c3ab3ea39533156a971e2c27:140a26cdc291b97362d7871f4bb8febd,c51d777ad31b365fbd3e4a495d775b7f:113dcc0ba22298b5cd84dd5a940e2fc4,02d7803549743012a928bf83f8930112:d64552117bce3ee771a976ff59b70227,0f6f2ab018ba32d3b0828892f927c409:0ff7e2e3e301d2e1b50dc57f0240a630,7c548a38f3ea4fcd8e7d6d1a9c14e6cb:dcfccb0ebbdd1583e73acf7a0f88d2be,03045f17d11e3e1aaa2e83ecb2b81b0b:3ae4b660d7192f9c89cbc07cd85b8143,e14507fe5ab032b785c1d5001288b8a2:8c64978fc2a2ff0733af23936dc50cc7", "Subtitles": "https://dvt-subtitles.persgroep.be/ESCAPEROOM_1F686563_04c772df-ab6d-48fb-884a-131dcae7ede9_vtt_nl_clipped.vtt" }
Subtitles have missing lines
By TitasxD in forum Video Streaming DownloadingReplies: 9Last Post: 11th Feb 2025, 14:27 -
Help with vtm go decryption keys
By Meta_emily in forum Video Streaming DownloadingReplies: 8Last Post: 27th Aug 2024, 05:03 -
Audio Decryption Working - Video Decryption not working
By citybuild122 in forum Video Streaming DownloadingReplies: 5Last Post: 4th Jul 2024, 12:50 -
Would appreciate help in getting decryption keys for VTM GO series
By Reflex9133 in forum Video Streaming DownloadingReplies: 1Last Post: 26th Aug 2023, 19:05 -
Anyway to download from VTM GO?
By DarkSmile in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2021, 11:49
